Date/Time: Tue, 22 Sep 2026 22:22:21 +0000
Market Depth
View Count: 807
| [2024-07-11 14:13:20] |
| User749040 - Posts: 45 |
Hello SC Support, I see there is an option under Chart Settings > Market Depth > Market Depth Highlight High Threshold Value although whatever value I put in there I don't see it reflect on the market depth. I also saw that there is an option to change the colors for it under Graphic Settings. Also there is nothing about it in the documentation. Am I missing something or this is just getting implemented and not live yet? Thank you. |
| [2024-07-11 14:35:09] |
| Sierra_Chart Engineering - Posts: 24938 |
This has not been fully implemented yet and does nothing. There are many steps to do this and only some of it is done.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2024-07-11 14:35:16
| [2024-07-11 14:41:16] |
Is there expected time for when this would be done or you will get to it whenever you have time?
| [2024-07-11 16:59:08] |
| John - SC Support - Posts: 47980 |
It is being worked on, but we can not say when it will be completed.
