Date/Time: Fri, 18 Oct 2024 04:00:20 +0000
Lmax trading service
View Count: 333
[2024-07-11 08:18:06] |
yang_sc_demo - Posts: 15 |
read on a previous post that SC stopped supporting Lmax for FX....then i came across this page: LMAX Trading Service so ...is Lmax + SC still available or not? can i recieve Lmax data feed in the U.S ? since SC support page for Lmax is short compared to SC+IBKR....is Lmax+SC more robust with less issues than sc+ibkr? thx Date Time Of Last Edit: 2024-07-11 09:53:33
[2024-07-11 11:18:02] |
Sierra_Chart Engineering - Posts: 16656 |
Yes LMAX is supported. But we understand they do not take customers from the US. Are you just interested in the data feed only and not trading?
[2024-07-11 19:49:36] |
i am intereted in FX trading ....not interested in paying 300$/month for Lmax FX data. SC documentation states : "Sierra Chart uses a connection model for the LMAX Exchange where there are no monthly fees from LMAX Exchange..." and "It is not recommended to use the direct LMAX FIX connection that Sierra Chart also supports. This does not support what is described in the above paragraph and has a 300 USD/month fee from LMAX" i assume this is still valid ?...if yes....what account type/setup do we ask Lmax for to enable this ? |
[2024-07-11 20:26:20] |
First thing is to contact LMAX and see if they will take your account. If so, let us know.
[2024-07-19 19:59:52] |
SC Support - Posts: 1888 |
Hi yang_sc_demo, if you can create an Account with LMAX we can set you up to connect your Sierra Chart Account with your LMAX Account. LMAX Trading Service |
[2024-07-20 07:11:44] |
I checked with LMAX...getting the account is not a problem.....their liquidity and spreads are ! it would be great if SC would create hooks to MT4/MT5/ctrader...etc. This would open up alot more options to forex traders and bring in many users to SC. |
[2024-07-23 21:54:19] |
Ok thank you for that information.
