Date/Time: Fri, 18 Oct 2024 05:57:06 +0000
current high low range marker on minute chart?
View Count: 122
[2024-07-10 23:49:28] |
LAdisa - Posts: 17 |
Hello, is there a study that will plot the range from high to low in ticks on the current bar? I have the indicator that does it on NT8 and was hoping to have that option with Sierra. Thanks.
[2024-07-11 13:57:37] |
John - SC Support - Posts: 35333 |
There are a number of ways to get this, depending on how you want to see it. Start with the "True Range" study to get the range of each bar. If that is all you need then you can stop here. Refer to the following: True Range If you want to display the current bar's value in large text somewhere on the screen, then use the "Text Display for Study" study. Refer to the following: Text Display For Study Or if you want to display the range as a value above or below the current bar, then use the "Study Subgraph Above/Below Bar as Text". Refer to the following: Study Subgraph Above/Below Bar as Text For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-07-11 14:45:39] |
John...You are much appreciated...thank you!
