Date/Time: Sun, 08 Sep 2024 00:26:59 +0000
Mini Taiex futures (MXF)
View Count: 101
[2024-07-10 16:17:01] |
User842913 - Posts: 4 |
Hello Sierra Chart, Would it be possible to use Sierra Chart to trade Mini Taiex futures (MXF) on Taifex via CQG ? |
[2024-07-10 17:06:56] |
If CQG has that data available and allows for trading it, then yes, you can do this. You will have to enter the actual CQG symbol in the "Find Symbol" window, as we do not list data for Taifex.
[2024-07-10 20:21:10] |
Sierra_Chart Engineering - Posts: 16292 |
Not necessarily. Our advice would be that this is not tradable from Sierra Chart when using CQG.
