Date/Time: Mon, 25 Nov 2024 09:05:00 +0000
Crosshair & Chart Values
View Count: 1963
[2013-05-08 04:23:47] |
emjay2d - Posts: 5 |
Is it possible to get the X axis Chart Values to show up near my Crosshair? Having trouble searching through documentation/support for the answer. Thank you very much for the awesome product and awesome support. Edit>> Another question -- Is it possible to see a 4 or 5 hour chart? Edit>> Last one -- Can I add commas to the "volume" analysis..? Its hard to read 4000000000 without commas. (I could just be uneducated and be missing something, not sure) Have a great day. Date Time Of Last Edit: 2013-05-08 05:44:28
[2013-05-09 01:58:33] |
1. Look at the Compact Tool Values Window. It is documented here: http://www.sierrachart.com/index.php?l=doc/doc_Tools.html#ViewingToolandChartData 2. Refer to the documentation here: http://www.sierrachart.com/index.php?l=doc/doc_KeyboardCommands.html 3. This will be improved upon. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
