Date/Time: Tue, 06 Oct 2026 12:12:42 +0000
[Programming Help] - Issues about sc.CancelAllOrders()
View Count: 1232
[2024-07-10 14:53:20]
Tony - Posts: 725
I am trying to cancel stop order when there is no position by using sc.CancelAllOrders(), everything works great until I press "Insert" key to reload and recalculate the chart, the stop order disappeared even I still had a position, so I tried to fix the issue by doing this:
  if (sc.IsChartDataLoadingInChartbook() || sc.IsFullRecalculation || sc.ChartIsDownloadingHistoricalData(sc.ChartNumber)) {
    // do something
  else {
    s_SCPositionData PositionData;
    sc.GetTradePosition(PositionData);
    if (PositionData.AveragePrice == 0.0) {
      sc.CancelAllOrders();
But the stop order still got canceled after reload and recalculation while I had an open position.
Wonder what I had missed,
Thanks!
P.S.
Originally, the stop order also got canceled after I remove and add this custom study, that part has been fixed by adding the code showed above.
Date Time Of Last Edit: 2024-07-10 15:25:58
[2024-07-10 15:09:35]
ForgivingComputers.com - Posts: 1239
// Generally you want to return in this conditional:
if (sc.IsFullRecalculation || sc.ChartIsDownloadingHistoricalData(sc.ChartNumber)) {
return;
// Then check if in a position and working orders
int Open_Position = PositionData.PositionQuantity;
if (!Open_Position && PositionData.WorkingOrdersExist) {
[2024-07-10 15:20:16]
Tony - Posts: 725
Hi bradh,
Thanks for your reply, I tried to return that condition, I still have the same issue.
One thing had been fixed is that after I remove/add this study or release/load DLL, the stop order will not be canceled, which is what I wanted.
[2024-07-10 15:35:27]
User431178 - Posts: 908
As well as
there is also
PositionData.NonAttachedWorkingOrdersExist
Which seems might be appropriate?
[2024-07-10 17:10:03]
The first one is all working orders, the second is only Non-Attached Orders, so I would use the first one.
[2024-07-10 19:46:09]
Tony - Posts: 725
Hi bradh and User431178,
Thanks so much for the feedback, unfortunately I tried all the possible solutions, none of them works.
I get around the issue by delaying the open-position check for a few loops right after reload / recalculation:
static int LoopCount {0};
LoopCount++;
So this number will be increased by 1 per loop through the lifespan of the study, but will be reset to 0 every time reload or recalculate happened.
And open-position check only happens when the value of LoopCount is greater than a certain number, i.e. 3
Now the stop order will never be canceled when there is an open position, as I expected.
I think I misunderstood with either of these 3 function / variable:
I hope engineering team will have a better solution, my code looks ugly now.
Date Time Of Last Edit: 2024-07-11 05:44:45
