Date/Time: Sun, 08 Sep 2024 00:31:02 +0000
TopStep set up
View Count: 96
[2024-07-10 14:21:39] |
User577837 - Posts: 4 |
Hello, I'm trying to connect to the Topstep server via service Rtihmic. I've received a connection error message much like the self help instructions posted within Sierra Chart. I have triple checked my credentials and all are correct. I have also gone through the CME non professional check instructions carefully. Would you be able to guide me in what step(s) I must be over seeing in connecting with Rithmic via Topstop? Many Thanks, Brian |
[2024-07-10 15:26:17] |
What is the exact error you are getting? If it is a "Permission Denied" error, then refer to the following: Rithmic Trading Platform Service: Permission Denied Resolution Procedure For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
