Date/Time: Thu, 10 Sep 2026 15:12:44 +0000
Binance data issues
View Count: 483
| [2024-07-10 13:25:16] |
| User100912 - Posts: 131 |
Quote boards showing high/low 0/0 for BTCUSDT_PERP_BINANCE and ETHUSDT_PERP_BINANCE Missing data in charts for these symbols. Updating to latest version and deleting/redownloading chart data hasn't resolved problem. |
| [2024-07-10 15:19:49] |
| John - SC Support - Posts: 47831 |
It looks like it is a problem with just one of our servers. Please select "File >> Reconnect", which will then connect you to a different server and you should get the current data flowing and be able to get missing data. We are looking into the issue with the system that has the problem. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
