Date/Time: Wed, 27 Nov 2024 11:41:58 +0000
Log sent in
View Count: 1125
[2014-08-26 09:39:09] |
ripsdips - Posts: 143 |
I sent a log in for review
[2014-08-26 10:02:25] |
At the time you see this message below what is the memory use of Sierra Chart? You can see this in the Windows task manager Encountered an out-of-memory condition when calling a study function. | 2014-08-26 09:35:16 Are you running any custom studies? For more information about those, refer to help topic 17 here: http://www.sierrachart.com/index.php?page=doc/helpdetails17.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-08-26 10:09:54] |
no I am not using custom studies. I did not go to resource monitor on task manager to see sierra memory usuage but I know that I was using up 40% of memory as per task manager on a 64gig machine.
[2014-08-26 15:57:17] |
Go to the Processes tab of the Windows Task manager a look at the SierraChart.exe process. What is the Memory (Private Working Set) when you notice this problem.
[2014-08-26 16:24:31] |
137,996k, it stopped doing it. I think I downloaded to musch data and I deleted and reloaded some of it
[2014-08-27 05:05:24] |
OK so it sounds like you are fine now. The memory reading you have given now is not too high to cause a problem.
