Date/Time: Sun, 08 Sep 2024 00:39:42 +0000
Colour Background Based on Alert Condition and Cumulative Delta Bars
View Count: 122
[2024-07-10 08:07:45] |
StephenL - Posts: 94 |
I have the Colour Background Based on Alert Condition set to region 2 which is on the Cumulative Delta Bars. However, I subsequently lose the Value Scale. You can see I have I have line set to 0 but it doesnt come up correctly. I added in the Study Settings as well.
Date Time Of Last Edit: 2024-07-10 08:14:41
![]() ![]() Attachment Deleted. |
[2024-07-10 13:32:31] |
Please reset the scale and let us know if that does not resolve it. Refer to the following: Chart Scale and Scale Adjusting: Resetting the Scale For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-07-10 14:28:01] |
Nope, that didnt fix it.
[2024-07-10 14:57:52] |
Sierra_Chart Engineering - Posts: 16292 |
Change the Study Display order so that the Color Background study, is higher up in the list of studies: Chart Studies: Study Display Order Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-07-10 15:24:46] |
That sorted it, thanks!
