Date/Time: Fri, 11 Sep 2026 20:12:13 +0000
3 Denali Connection limit & Multiple Sierra Installs
View Count: 963
| [2024-07-09 21:36:35] |
| WVU07 - Posts: 2 |
Hello, my question is regarding using additional copies of Sierra Chart while adhering to the limit of 3 Denali connections. I'm using a 3rd party external trade copier [SST Copier] to copy from a main install that will be on a live funded account with Denali & Teton. This will be copied to n number of Sierra Installs connected to Rithmic. The setup looks as follows: #1 Denali & Teton #2 Rithmic #3 Rithmic #4 Rithmic ...etc With the following settings on the Rithmic installs: Global Settings >> Data/Trade Service Settings >> Common Settings >> Allow Support for Sierra Chart Data Feeds == NO
Trading Username and Password == FILLED
Market Data Username and Password == EMPTY Historical Data Username and Password == EMPTY 1. Would this setup work and allow for n numbers of Sierra Installs using Rithmic? 2. Can Sierra submit orders to the Rithmic service without any market data or does the Market Data Username and Password field have to be filled out? |
| [2024-07-09 22:12:56] |
| Sierra_Chart Engineering - Posts: 24837 |
This will work. Market data is not necessary to submit orders. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
