Date/Time: Fri, 18 Oct 2024 04:10:08 +0000
How do I invert what the y-axis does?
View Count: 106
[2024-07-09 13:51:12] |
User429142 - Posts: 42 |
I'd like to invert what the y-axis does when I grab it and drag it down. The way it currently works: When i grab it and pull down it stretches the bars more. How do I reverse this so dragging down shrinks the bars. |
Screenshot_2.jpg / V - Attached On 2024-07-09 13:49:25 UTC - Size: 157.87 KB - 26 views Attachment Deleted. |
[2024-07-09 17:02:19] |
John - SC Support - Posts: 35333 |
Refer to the following: General Settings Window: Interactive Scale Range Movement Adjust Direction (Global Settings >> General Settings >> Charts >> Charts) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
