Date/Time: Sun, 08 Sep 2024 02:08:23 +0000
CBOE Global Indexes
View Count: 163
[2024-07-09 13:12:23] |
ninjus - Posts: 29 |
Any update on historical data? Need it real bad :)
[2024-07-09 13:22:46] |
Sierra_Chart Engineering - Posts: 16292 |
No this is actually quite involved to implement.
[2024-07-19 08:21:20] |
Im finding an issue where Daily Historical CBOE Globel Index symbols are only updating on the main instance of SC. If I have other instances open or other installs in other folders these arent downloading current data. Ive been having to manually copy my dly file across folders to maintain things. Some times if I delet data and download it fixes it something it does not. Either way Im having to manually intervene in some way every day. |
[2024-07-19 12:14:48] |
We are checking on this.
[2024-07-19 12:20:20] |
We are not able to reproduce this problem. Do you have any issues with Intraday charts updating in real time in a sub instance for CBOE Global indexes? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2024-07-19 14:52:13
[2024-07-19 12:26:39] |
No. Although I dont need the intraday data so dont watch it. I just need prior day settlement. I use it to make some calculations the following day and when it doesnt automatically update its throwing everything off. I will watch the intraday chart later when they are open and report back. |
[2024-07-19 14:28:34] |
Intraday charts in sub instance appear to be fine.
