Date/Time: Fri, 18 Oct 2024 04:15:16 +0000
Chart Daily Drawdown, Daily Max, PNL
View Count: 176
[2024-07-09 08:00:10] |
Fungraphic72 - Posts: 6 |
Hello, is it possible to do as on the screen but with multiple accounts. For example, if I have several propfirm accounts, can I summarize the states on the same chart? If so, can you tell me how? Thanks in advance. |
Daily PNL .png / V - Attached On 2024-07-09 07:59:42 UTC - Size: 13.13 KB - 38 views |
[2024-07-09 16:41:44] |
John - SC Support - Posts: 35333 |
Depending on the study, if it has a Subgraph associated with it (such as the "Maximum Drawdown" and "Daily Profit/Loss") then you can have those on a chart that has a specific Trading Account set for it, and then you can use the "Study/Price Overlay" to over those studies to the chart with a different account. Refer to the following: Study/Price Overlay Study For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
