Date/Time: Sat, 03 Oct 2026 11:43:38 +0000
Trimmered or truncated mean
View Count: 522
[2024-07-09 07:29:17]
User251043 - Posts: 50
Is there any study to calculate a truncated moving average? I would like to have a study where I specify the % of extreme values to be discarded and then calculate the average with the rest of values.
Thank you.
[2024-07-09 16:35:14]
John - SC Support - Posts: 48095
We do not have a study that does this. You could use the Spreadsheet Study to control the particular data and then use the "Moving Average Simple - Skip Zeros" to get your moving average of the modified data. Refer to the following:
Using the Spreadsheet Study
Moving Average - Simple Skip Zeros
Otherwise, you could create a custom study that does what you want. Refer to the following:
How to Build an Advanced Custom Study from Source Code
List of Third Party Sierra Chart Study and System Programmers
