Date/Time: Thu, 19 Sep 2024 21:59:54 +0000
sg structure
View Count: 947
[2014-08-26 02:28:35] |
Netz - Posts: 19 |
Hello. What is the difference between the sg structure and sc structure? I looking to modify some user contributed studies and I see them as sg structure. Thanks. |
[2014-08-26 05:28:44] |
There is no difference. We recommend renaming it "sc".
