Date/Time: Mon, 22 Jul 2024 10:48:59 +0000
[Programming Help] - ASCYL custom study synchronization with the spreadsheet
View Count: 44
[2024-07-08 18:38:23] |
Hopeman - Posts: 161 |
Hello, I have problems with the code, I am trying to simulate the Time and sales study in the spreadsheet using code. Although I have managed to have the data in the spreadsheet I have problems with the synchronization in the spreadsheet when a filtered value above 20 appears in this case it does not go down to the next cell, it disappears and sometimes there are values that appear on the tape but in the studio No. Could you be so kind as to tell me where the problem could be? It seems that some function is missing that makes the values go down the cell. To solve this problem, it may be that it fixes the fact that not all the trades are visible. I would have no problem sharing the code so they can see it since it is simple Thanks in advance |
