Date/Time: Sun, 08 Sep 2024 03:04:36 +0000
No MBO data
View Count: 133
[2024-07-08 18:38:20] |
cmack1011 - Posts: 46 |
I'm currently running SP12 on the latest ARM version of SC with Windows11 using the NVDA_MBO[M] symbol, but I'm not seeing any MBO data? Also, is it possible to compress "Current Traded BID/ASK Volume" in the DOM? Thx |
Screenshot 2024-07-08 at 12.14.36.png / V - Attached On 2024-07-08 18:37:58 UTC - Size: 271.2 KB - 26 views |
[2024-07-08 20:07:52] |
Make sure you have gone through the following instructions: Market By Order Data: Step-by-Step Instructions There is no support for compressing the "Current Traded Bid/Ask Volume" columns. We have only implemented support for the main Bid/Ask Market Depth and the Recent Bid/Ask volumes columns. Refer to the following: Chart Settings: Market Depth Combine Increment in Ticks (Chart >> Chart Settings >> Market Depth menu) Chart Settings: Apply Combine Increment in Ticks to Recent Bid/Ask Volume Columns (Chart >> Chart Settings >> Market Depth menu) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
