Date/Time: Sun, 08 Sep 2024 03:12:52 +0000
Deleting data from charts
View Count: 71
[2024-07-08 18:13:25] |
Jonathan Rizza - Posts: 1 |
Good afternoon, I wanted to know if there is a way to delete Sierra's data in terms of history because it takes up too much space on my computer. Could you send me a guide on how to delete the data for a certain period of time?
[2024-07-08 18:25:04] |
Refer to the following: Chart Data and Chart Data Files: Cleaning Up Old and Unused Symbols for Efficiency Also, the following may be helpful to you: Global Settings Menu: Intraday Data File Management (Global Settings menu) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
