Date/Time: Sun, 24 Nov 2024 01:06:06 +0000
Resolved a problem with the Text Tool Properties/Configuration window
View Count: 168
[2024-07-08 15:19:23] |
natanibz - Posts: 134 |
Hello, I still have these problems regarding the Text Tool configuration, even in the latest version. Thanks
[2024-07-08 16:33:15] |
What are the problems? Make certain you are on the latest version of the software - v2654. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-07-08 17:14:25] |
I'm using v2654 When I save some text in text properties/ tool configuration(list), it doesnt save my text (like it did before) but it save only the text font |
[2024-07-08 18:22:31] |
Please give us the exact workflow you are using, including which tool you are selecting.
