Date/Time: Sun, 08 Sep 2024 03:04:40 +0000
Current price level not moving with Teton or Rithmic, Sim or Live
View Count: 81
[2024-07-08 14:42:31] |
User368639 - Posts: 40 |
Price not moving on chart. Connected to Rithmic. Same result with Teton. Will be sending a copy of Message Log. |
[2024-07-08 16:08:00] |
Sierra_Chart Engineering - Posts: 16292 |
This is the issue: 2024-07-08 16:43:07.652 | Denali Data Feed | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2
Refer to: Denali Exchange Data Feed: Connections Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2024-07-08 16:08:21
