Date/Time: Sun, 08 Sep 2024 04:55:38 +0000
Chart Overlay
View Count: 82
[2024-07-08 12:03:43] |
Ghosttrader - Posts: 21 |
Hello, I added the Heiken Ashi candles to a chart but I have a custom study I use to detect delta dominance. Basically changes the color of the bar based on dominant buyers/sellers. It works fine with normal candlesticks but when I added the Heiken Ashi candles I can't get it to work. Not sure if I need to create a overlay chart or am I doing something incorrect here. Please advise. thank you. |
[2024-07-08 13:06:12] |
Sierra_Chart Engineering - Posts: 16292 |
Check the calculation and Display order of the studies: Chart Studies: Study Display Order Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2024-07-08 13:06:20
