Date/Time: Sun, 08 Sep 2024 04:55:26 +0000
Trade Copier
View Count: 127
[2024-07-08 09:47:41] |
Kadodia12 - Posts: 12 |
Hi I found there is an issue with the built in trade copier; when I go to Order Allocation to Trade Accounts from the trading window settings, add the accounts and select apply and ok, it reverts to the same account being selected under 'Available Accounts' and 'Allocation Accounts'. Please could you help resolve this issue. It used to work as expected until recently. Thanks |
[2024-07-08 13:02:31] |
Sierra_Chart Engineering - Posts: 16292 |
This is not clear enough for us. On the Order Allocation Settings window there are two Global Settings. Set these both to No. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2024-07-08 13:03:49
