Date/Time: Sun, 08 Sep 2024 03:02:07 +0000
Chart book loading in too small
View Count: 165
[2024-07-08 07:47:24] |
User821986 - Posts: 9 |
My sierra chartbook is loading in a lot smaller than it is supposed to and I don’t know what to do
Date Time Of Last Edit: 2024-07-08 12:46:01
[2024-07-08 12:45:50] |
Sierra_Chart Engineering - Posts: 16292 |
Only follow the instructions here to provide an image of the chart: Support Board Posting Information: Attaching or Posting a Screenshot/Image (Optional) Follow the instructions here to reset the chart scale: Chart Scale and Scale Adjusting: Chart Bars or Studies Not Completely within View, Not Displayed, or Cut Off. Reset Scales. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-07-08 13:14:35] |
https://www.sierrachart.com/image.php?Image=1720444445147.png
[2024-07-08 16:01:48] |
Refer to the following: Numbers Bars: Scaling a Numbers Bars Chart Numbers Bars: Font Size Mode For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
