Date/Time: Sun, 08 Sep 2024 03:08:19 +0000
[Programming Help] - Enable to global data feeds
View Count: 133
[2024-07-08 05:46:35] |
User676364 - Posts: 1 |
Hello team I am trying to enable to global data feed -india , but it shows my service package wasn't enable for DTC service . |
Private File Attachment Deleted. Private File |
[2024-07-08 15:45:31] |
You are on a trial. You can not connect to data or trading services while on a trial. If you want to connect to "Global Data Feeds - India", you will have to change to one of the "Integrated" packages. Refer to the information here: Description of Service Packages and Pricing: Integrated Packages Follow the instructions at the following link for how to add funds and change to a paid package: Sierra Chart Purchase and License Information: Instructions For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
