Date/Time: Sun, 08 Sep 2024 05:01:00 +0000
limited historical data
View Count: 86
[2024-07-07 20:53:33] |
User270283 - Posts: 1 |
hello. for symbol "100USNote" from FXCM , both historical chart and Intraday chart start just from date: Jun2023 and before that date is missing. I tried "Download Data - Historical Chart". did not change. I have updated to last version 2654. cannot I have data from like 2018 ? thanks for helping. |
[2024-07-07 21:07:16] |
Sierra_Chart Engineering - Posts: 16292 |
No, this is not available with that CFD symbol. So you need more historical data for the 10 year US note? We can check on adding that with our new CBOE global indexes data feed. But it can still be a few weeks away. The symbol with that data feed is: TNX_CGI Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2024-07-07 21:08:10
