Date/Time: Sun, 08 Sep 2024 03:02:32 +0000
Tradevote
View Count: 133
[2024-07-07 18:25:43] |
User274479 - Posts: 1 |
I trade for APEX and use tradeovate. Can I use Sierra Charts if I open a brokerage acct at Stage 5 I knowbut is Tradeovate? Rhytmic is supported |
[2024-07-08 15:26:22] |
Tradeovate does not support the use of Sierra Chart, therefore you can not use Sierra Chart with Tradovate. You can use Sierra Chart with Rithmic with APEX. And if you want to get the real-time data for the CME Group from us, then you would need a brokerage account in order to qualify for the Non-Professional exchange fees from the CME Group. We recommend the solution outlined at the following link: Easy Solution to CME Funded Trading Account Requirement For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
