Date/Time: Sun, 08 Sep 2024 03:06:42 +0000
Cross Hair Label Issue
View Count: 102
[2024-07-07 15:52:26] |
Mitch1840 - Posts: 11 |
Please see attached picture. I want to remove the small window which appears when I move the crosshairs on the candles. Please let me know which settings to turn off |
remove the window.jpg / V - Attached On 2024-07-07 15:52:12 UTC - Size: 37.53 KB - 35 views |
[2024-07-08 15:16:50] |
That is the "Compact Tool Values Window". Select "Window >> Show Compact Tool Values Window" to remove the checkmark next to this item, which will have it not show up with the crosshair. Refer to the following: Chart Drawing Tools: Compact Tool Values Window For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
