Date/Time: Sun, 08 Sep 2024 04:57:34 +0000
Candles disappear/appear during scrolling
View Count: 168
[2024-07-07 09:48:34] |
User385529 - Posts: 2 |
Hey There, I've suddenly run into this weird issue where when I scroll backwards or forwards in in time on the chart, candles are getting cropped off and seem to appear/disappear. You can see the behaviour in this video: https://www.youtube.com/watch?v=tX1l0zDCtCs Can you tell me what setting could be causing this? (I may have pressed something that enabled it by accident) Thanks |
[2024-07-07 13:50:24] |
Sawtooth - Posts: 4083 |
Right click in the price axis and choose 'Scale Range: AutomaticOr double click in the price axis maximize the candles in the chart region. |
[2024-07-08 00:22:40] |
Sierra_Chart Engineering - Posts: 16292 |
Refer to: Chart Scale and Scale Adjusting: Chart Bars or Studies Not Completely within View, Not Displayed, or Cut Off. Reset Scales. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-07-08 02:10:54] |
awesome, thanks. In the end it was Chart >> Reset Scales that fixed this! Cheers! |
