Date/Time: Sun, 08 Sep 2024 04:50:57 +0000
btcusdt chartbook
View Count: 130
[2024-07-06 19:51:11] |
ShaiVardika - Posts: 11 |
hey, i made a new chartbook on a seperate SC installation and open BTCUSDT Perpetual from Binance seems like everything works okay but the thing is - the chartbook is so SLOWWWW, scrolling is slow, using tools, like each click on the mouse it responded like 5 second later, if i want to add a study it takes a lot of time to load i have 4 charts - daily,60 mins, 30 mins and TPO chart in the chartbook and it only happen in this chartbook when i get back to the example chartbook - everything works smoothly is there anything to do? |
[2024-07-06 21:03:36] |
Sierra_Chart Engineering - Posts: 16292 |
Refer to: Cryptocurrency / Bitcoin Data and Trading Services: Important: Volume at Price Studies with Cryptocurrency Symbols Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-07-06 21:35:16] |
omg thank you so much it works well now
