Date/Time: Wed, 27 Nov 2024 10:35:42 +0000
Replay only advances by 1 minute increment starting in 2014
View Count: 1245
[2014-08-25 20:26:15] |
User588428 - Posts: 3 |
Hello I've noted when replaying the charts that starting in 2014 the chart advances in 1 minute increments only during replay. As it is playing it does not show the individual price movements (or skips prices) of the bar as it develops say for a 5 minute bar. The clock at the top only shows advancement in minutes i.e. the seconds always show :00 -- only minutes advance. In turn the bars are not showing how the open/close/high and low develop during the 5 minute time frame (5 minute chart). When I go back to previous years it works fine as it had before. I deleted the ES file and re-loaded the symbol with same results. Is this something new with SC or is it something on my end? Thanks! |
[2014-08-25 20:52:52] |
Tell us the exact symbol of the chart where you notice this.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-08-25 20:53:06
[2014-08-26 14:26:58] |
ESU4 any of the contracts in 2014 (H M or U)only replay in 1 minute increments (no seconds or bar evolving) static until next minute arrives and then the next bar appears. If I change the year to 3 or before it is fine on the replay. for years prior to 2010 I use 09 08 07 etc. Those replay fine as well. Thank you |
[2014-08-26 15:36:05] |
This is not the correct symbol. In the case of when using the Sierra Chart Historical Data service, all years are 2 digits. You can find the correct symbols in File >> Find Symbol. Also make sure you have a tick by tick data configuration: http://www.sierrachart.com/index.php?page=doc/doc_TickbyTickDataConfiguration.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-08-26 15:37:13
[2014-08-26 19:09:31] |
Got it. Thank you!
