Date/Time: Mon, 21 Apr 2025 04:47:18 +0000
intraday charts won't load data past a date
View Count: 253
[2024-07-05 19:35:57]
Shlomi.B - Posts: 50
in a chartbook I have both historical (monthly and daily) and intraday charts (65m / 10m). the historical charts seems to be up to date but the intraday charts won't show data past 4.29.24
in the chart settings under data limiting the range is 3.20.23-7.5.24 and is marked as intraday chart. its not showing me anything past 4.29.24
I tried downloading the data but nothing works. I tried days to load but that doesn't work ether. how can I download the data so the chart is current?
the symbol im looking at is NVDA if that matters.
[2024-07-05 20:04:58]
John - SC Support - Posts: 39362
Please do the following:
- Open a chart for NVDA
- Select "Window >> Message Log".
- On the Message Log select "Edit >> Clear Log".
- Select "Edit >> Delete All Data and Download".
- Wait for the data to download and then populate the chart.
- Get us your Message Log by following these instructions:
Also, let us know if you did or did not get the most recent data after doing this.
[2025-03-13 09:41:37]
ralphdavies01 - Posts: 3
Hello, I am facing a similar issue with NQ and ES futures. I have tried the procedures that were outlined above, along with a few other logical steps, but none seem to work. I have sent through my message log at 09:38 GMT after trying Edit >> Delete and download all data. Any help would be appreciated.
Many thanks,
Ralph
[2025-03-13 14:39:51]
ralphdavies01:
From your log, you have the wrong symbols. Each service uses a different symbology, and your symbols are setup for what Rithmic needs, but your "Current Selected Service" is set to "SC Data".
Select "Edit >> Translate Symbols to Current Service" to solve this.
Please post in a new thread when you have something like this, even if you think it is related to an old thread, which 99% of the time, it is not.
