Date/Time: Fri, 22 Nov 2024 07:47:51 +0000
Expanding space between bars on a chart
View Count: 2739
[2013-05-08 01:28:29] |
User16189 - Posts: 4 |
How do I expand the space between bars on my charts, so bars are not so close together. Thank You |
[2013-05-08 01:30:59] |
M5amhan - Posts: 468 |
click on your chart go to the chart tab at the top left and there are different options in the bottom right corner of the menu, you can change width or spacing |
[2013-05-08 01:45:00] |
Please see: http://www.sierrachart.com/index.php?l=doc/doc_WorkingWithCharts.html#ChangingBarSpacing Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-05-08 01:46:53] |
I am working with a chart book, I don't see what you suggested. Can you post a snap shot? THX |
[2013-05-08 01:50:15] |
I got it, Thank You Very Much!!!
