Date/Time: Sun, 24 Nov 2024 01:21:43 +0000
Sierra Charts (Rithmic) not updating to the current days market
View Count: 159
[2024-07-05 16:04:42]
User522181 - Posts: 3
I appreciate the way that you have assisted me with the previous issues, Thank you.
When I opened the charts today, I noticed that they didn't go any further past the date of 06/21/24. I have switched from using delayed data to Rithmic Dtc direct trading via TOP step trader in order to take a funded challenge. How can I fix the issue with the date and access the current days market? Even though I am connected to the data via Rithmic this message appears on the screen when the charts are downloading, "download failed error downloading historical Intraday Data for ESM24-CME exchange not specified "
[2024-07-05 16:32:34]
You have the wrong symbols for Rithmic. Every service uses a different symbology. When you change your Current Selected Service and select OK to close the Data/Trade Service Settings window, you are presented with a question about updating symbols. You should answer "Yes" to this question.
If you do happen to say "No", or if you open a different chartbook later, then you can update the symbols by selecting "Edit >> Translate Symbols to Current Service".
