Date/Time: Sun, 24 Nov 2024 01:28:32 +0000
Change Study Settings on Symbol
View Count: 128
[2024-07-05 15:07:40] |
User131975 - Posts: 78 |
Hello, is it possible that I can set the studys so that when I call them up on different symbols the settings automatically adapt to the symbol? e.g. MNQ TPO Ticks -> 6 MES TPO Ticks -> 1 |
[2024-07-05 16:27:51] |
To do this fully automatically, you would need to develop a custom study that would do this for you. Refer to the following: sc.SetChartStudyInputInt() List of Third Party Sierra Chart Study and System Programmers In terms of existing built-in tools, the only option would be to have different Study Collections setup so you can change the particular study settings relatively quickly. Refer to the following: Study Collections For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
