Date/Time: Sun, 08 Sep 2024 04:59:27 +0000
Engineering - Please add Ctrl Bars 9-10-11-12 to Customize Toolbar Menu.
View Count: 227
[2024-07-05 14:23:47] |
User92573 - Posts: 519 |
Dear Support Please add Ctrl Bars 9-10-11-12 to the Customize Toolbar Menu >> Trade Window >> ...... We have Ctrl Bars 1 - 8 and the addition of 9 - 12 would be really helpful. Many thanks. |
[2024-07-05 16:10:45] |
We are not understanding where you are looking that all 12 control bar options are not available. Please give us the specific location where you see this.
[2024-07-07 08:01:34] |
Hi John Just downloaded current version to make sure its still the same. When you select >> Customize Control Bar >> Window >> You are offered Buttons for Control Bars 1 - 8 but there are currently 12 available.
Would it be possible to add the other 4 Control Bars to the Menu? Many thanks Date Time Of Last Edit: 2024-07-07 17:09:00
[2024-07-07 21:03:01] |
Sierra_Chart Engineering - Posts: 16292 |
We know what you mean. We will do this.
[2024-07-08 08:59:24] |
Thank you!
[2024-07-31 15:36:31] |
This will be out in the next release.
[2024-08-01 10:04:52] |
Thank you!
