Date/Time: Sun, 08 Sep 2024 05:01:18 +0000
Time and sales setting plotted on the chart
View Count: 149
[2024-07-05 10:19:25] |
User494398 - Posts: 6 |
Hello i want to ask if could be implemented a features that allow sierra users to see the tape on the chart, I mean like a dots, but not with large numbers indicators or something else, basically a dots on the chart that have the same time and sales settings, i use combined setting "same time and same type, that is what i want to have like a dot on the chart, would be a great tool in my opinion and you dont need to watch the tape every time
[2024-07-05 15:34:16] |
You can essentially do what you are wanting by creating a chart set to a Bar Period of 1 trade. And you can use the "Large Volume Trade Indicator" to mark large trades. Refer to the following: Chart Settings: Intraday Chart Bar Period >> Bar Period Type >> Number of Trades Per Bar (Chart >> Chart Settings menu) Large Volume Trade Indicator The only thing this does not do is have the combining of "Same Time and Type". You can set the option for "Chart >> Chart Settings >> Chart Data >> Combine Trades Into Original Summary Trade" in the Chart Settings, as a way to combine. Refer to the following: Chart Settings: Combine Trades into Original Summary Trade (Data Feed and Exchange Specific) (Chart >> Chart Settings >> Chart Data >> Chart Data menu) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-07-05 15:39:25] |
thank you very much i will try it. I use the tape to trade with combined trades and a grafical visualizzation was good. maybe it can be coded via acsil?
[2024-07-06 13:31:27] |
Bedhog - Posts: 173 |
For years... I've been using doing this manually using ask/bid delta and outputting a point at the Numbers Bars Calculated Values:Point of Control Value. So today I've discovered the Large Volume Trade Indicator - wow it does a perfect job. So now I have a change request for SC Support :) Modify IN:21 HIGH|CENTER|LOW to include VPOC as a selection. Thank you! |
