Date/Time: Tue, 04 Nov 2025 19:21:24 +0000
Chart appeared on Trade DOM
View Count: 369
| [2024-07-05 06:30:04] |
| User745789 - Posts: 383 |
I had a Trade Dom in Chartbook A. I copied it to Chartbook B, closed Chartbook A, and changed the Data/Trade Service Settings and translated the symbols setting when prompted. Now my Trade DOM has a chart on it, near the volume by price profile. How do I get rid of that? See image |
| [2024-07-05 13:19:31] |
| Sierra_Chart Engineering - Posts: 21308 |
What studies are on that chart? You can see them through Chart >> Studies >> Studies to Graph.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2024-07-05 13:19:51
| [2024-07-07 02:30:20] |
I believe I found the cause. The original DOM used Study/Price Overlay to get some study values from another chart. In the new Chartbook, to which the chart was duplicated, that source chart does not exist [my error]. So for some reason, a bar chart appears on the DOM instead.
