Date/Time: Sun, 24 Nov 2024 01:45:14 +0000
Unable to get rid of the Volume Profile that is blocking the actual volumes
View Count: 130
[2024-07-05 03:06:10]
User640414 - Posts: 28
Not sure how the Volume Profile appeared ( bars in Red & White ). I do remember that I try to draw volume profile "Draw Volume Profile" from the Tool Bar. I try to "Erase All Drawn Volume Profiles" from the Tool bar and it did not work.
Would appreciate if you could guide me the process to get rid of the Volume Profile with Red and White Bars.
Pls find the attached screen shot image.
Best,
Basil
Private File
[2024-07-05 12:06:35]
Sierra_Chart Engineering - Posts: 17154
Remove these Volume by Price studies through Analysis >> Studies >> Studies to Graph.
