Date/Time: Sun, 24 Nov 2024 01:33:57 +0000
TPO VP only yesterday RTH
View Count: 165
[2024-07-04 12:35:33]
User131975 - Posts: 78
Hello
Currently I have the TPO chart set up the way I want it and you can only see today's overnight session.
But I can't find one thing and that is how do I make it so that I only see the volume profile from yesterday's RTH session?
I want to have everything exactly as it is now but I only want to see the volume profile for yesterday's RTH.
imageScreenshot 2024-07-04 143519.png / V - Attached On 2024-07-04 12:35:28 UTC - Size: 79.1 KB - 41 views
[2024-07-04 12:37:02]
Of course I meant that the volume profile shows the current RTH session.
So if it is currently an overnight session then the volume profile from yesterday should be there and when the overnight session is over and the market is open then the volume profile should only be active for the current RTH session.
[2024-07-04 13:08:01]
I have followed this guide:
Volume By Price Study: Single Volume Profiles At End of Chart
But now the volume profile is correct but it is on the right side.
Is it not possible to do it like in the screenshot above but only on the current day in the RTH session right next to the TPO profile?
imageScreenshot 2024-07-04 150748.png / V - Attached On 2024-07-04 13:07:56 UTC - Size: 61.38 KB - 42 views
[2024-07-05 14:36:32]
There is not a way to only have a single Volume profile displayed with the TPOs within the actual period.
When you add a Volume by Price profile that is associated with the TPOs, there will be a Volume Profile associated with each TPO profile. In this case, the only way to get a single period Volume profile is to use the Right aligned option (which is already set).
[2024-07-05 14:40:08]
Okay tank you.
Its okay i go with that
