Date/Time: Sun, 24 Nov 2024 01:57:54 +0000
Colors
View Count: 192
[2024-07-04 08:45:12] |
User131975 - Posts: 78 |
Hello i followed this guide: Chart Drawing Tools: Quickly Changing Colors / Line Style / Line Width But I can't find the things that are described there. I have no selection for these 8 colors. And if I change this TC1 and TC2 etc. then I can change the colors but not by the quick selection with right click on the line and "colors" then it is still empty |
Screenshot 2024-07-04 104435.png / V - Attached On 2024-07-04 08:44:45 UTC - Size: 52.14 KB - 38 views Screenshot 2024-07-04 104453.png / V - Attached On 2024-07-04 08:45:07 UTC - Size: 73.78 KB - 35 views |
[2024-07-05 14:15:47] |
Refer to the following: Chart Drawing Tools: Customizing Colors on the Menu If the colors do not show correctly after changing them, then this would imply an operating system issue for some reason. Reboot your computer and then see if they show properly. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-07-05 14:19:18] |
My Window looks completly different to this guides..
[2024-07-05 14:21:09] |
I want to change this short selection... I have no idea why there are already two colors in there and I don't know how they got in there.
Screenshot 2024-07-05 161958.png / V - Attached On 2024-07-05 14:21:02 UTC - Size: 58.65 KB - 35 views Screenshot 2024-07-05 162010.png / V - Attached On 2024-07-05 14:21:05 UTC - Size: 70.74 KB - 37 views |
[2024-07-05 16:09:01] |
We have not updated the documentation for that yet. But the basic concepts still apply. Select a configuration, or the Drawing Properties and then select the option for "Select Color". This will bring up the "Color Picker" and then you can set the colors of the Custom Colors as defined in the documentation.
