Date/Time: Wed, 27 Nov 2024 10:38:35 +0000
Indicator on indicator
View Count: 997
[2014-08-25 14:31:43] |
ripsdips - Posts: 143 |
Can I put a parabolic sar on an oscillator in a subgraph below price?
[2014-08-25 17:19:51] |
You can try this. Refer to the Based On setting for studies which is documented here: https://www.sierrachart.com/index.php?page=doc/doc_ChartStudies.html#BasedOn Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
