Date/Time: Sun, 08 Sep 2024 00:36:03 +0000
Chart Drawings/Modification from other charts
View Count: 90
[2024-07-03 18:18:51] |
cfuture - Posts: 67 |
Is it possible to incoporate functionality that would allow certain charts to be modified and others not instead of a general one size fits all? My longer timeframe charts have many line drawings which need to be left alone at all costs but when going to shorter timeframes, then it is necessary to make changes to the smallest timeframe used for entries.
[2024-07-03 18:37:26] |
If you are referring to drawings that are copied to other charts, then there is not a way to do this. You would have to have separate drawings for the charts. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
