Date/Time: Sun, 24 Nov 2024 01:23:45 +0000
No Data?
View Count: 192
[2024-07-03 17:46:52]
User109490 - Posts: 11
Hi everyone,
Since 12:14 (CT) my data just stopped. I tried reload/recalculate, then closed Sc, closed my machine, restarted both, to no avail. The issue is with both instances I have, using 2 different trading services (Rithmic and Amp/CQG), Denali should be overriding both.
What could be the issue here, can you help me sort this out?
Thx in advance,
Lex
[2024-07-03 18:10:16]
JD443814 - Posts: 2
Same issue here
[2024-07-03 18:14:50]
AC7303484 - Posts: 26
The market is closed.
[2024-07-03 18:35:35]
Specifically, the CME Group is currently closed for the U.S. Independence Day holiday. They will open again tonight (July 3, 2024) at 17:00 CDT and then close again at noon on July 4, 2024.
The U.S. Equities markets will be closed all day on July 4, 2024.
[2024-07-04 22:01:41]
JD443814 - Posts: 2
Got it. I use volume bars intraday and often get thrown off by the "open time" being associated with each bar instead of the "close time".
For example, on Wednesday, the last bar on my chart is listed as 13:11:27 when inspected by the crosshair. Is there a way to instead display it as 13:15:00? Or, is there another way to ascertain the close time of the last bar?
[2024-07-05 12:00:46]
Sierra_Chart Engineering - Posts: 17154
To see the closing time of a chart bar, refer to:
Bar End Time
