Date/Time: Sun, 08 Sep 2024 00:32:48 +0000
Creating two groups for order allocations
View Count: 138
[2024-07-03 13:39:28] |
vesak - Posts: 15 |
Hello, is it possible to create two groups for order allocation? Like: Group 1: Account 1 and 2 Group 2: Account 3 and 4 Thanks, Roman |
[2024-07-03 14:29:43] |
Sierra_Chart Engineering - Posts: 16292 |
Yes but you need to use different charts for this. Each chart has its own configuration for the Order Allocation to Trade Accounts. This is configured through the Trade Window for the chart.
[2024-07-03 14:47:43] |
vesak - Posts: 15 |
Okey and how does it work? I add Account 1 and 2 into the list on one chart and then the trade from either Account 1 or 2 will be copied to the other account? Or does only Account 2 be added into the list and I just trade with Account 1? Thanks, Roman |
[2024-07-03 17:02:33] |
Per the instructions, you only need to add the accounts to which you want to copy the orders. So if you are trading Account1 (Account1 is selected on the Trade Window) then you only need to add Account2 to the list of accounts to which the orders will be copied. Refer to the following: Order Allocation to Trade Accounts: Setup Instructions For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
