Date/Time: Sun, 24 Nov 2024 01:43:10 +0000
Unable to save configuration in the function
View Count: 156
[2024-07-03 12:47:17] |
User34758 - Posts: 2 |
In the function "Order allocation to trade account" (trade copier), it is not possible to save "Enabled" in the Trade Window Configuration, even though I have set Yes in the item Global settings-Order allocation to trade accounts Include In Save Trade Window Configuration. Although I will save the configuration, after every restart of sierrachart, or after choosing a saved trade window configuration, the order allocation to trade account is set to No.
[2024-07-05 16:09:20] |
Sierra_Chart Engineering - Posts: 17154 |
With regards to restarting Sierra Chart and the option for the Order Allocation to Trade Accounts being disabled, refer to the following setting: Global Trade Settings Windows: Disable Order Allocation To Trade Accounts on Chartbook Opening (Global Settings >> General Trade Settings >> General) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
