Date/Time: Thu, 10 Sep 2026 02:17:21 +0000
How to simply change the text tools font/size in the new form - it used to be so simple.
View Count: 684
[2024-07-02 21:54:37]
User92573 - Posts: 614
Dear Support
This used to be such a simple and intuitive exercise before the form was changed. Select the text, open the form deselect global and then just select the font and font size etc for the selected text.
Please tell me how to change the font and font size without having to set up a specific config number for the selected texts font and font size etc.
Images attached.
Many thanks.
imageSierra New Form Layout.png / V - Attached On 2024-07-02 21:53:50 UTC - Size: 107.87 KB - 170 views
[2024-07-02 22:11:14]
John - SC Support - Posts: 47822
- Set the option for "Use Drawing Specified Font" to "Yes".
- Click in the field to the right of "Font (Action)" and you will see a "Select" button. Select that button to bring up the Font Selection window. Set the font as you want in that window and select OK. Then select OK to close the Drawing Properties window and update the font for that drawing.
[2024-07-07 08:07:06]
That's the aha moment ... :-)
Many thanks
[2024-07-07 11:05:31]
Sierra_Chart Engineering - Posts: 24817
You must also update Sierra Chart to the current version.
