Date/Time: Sun, 08 Sep 2024 00:21:54 +0000
Can't get historical intraday data for more than 5 years ago
View Count: 115
[2024-07-02 13:45:26] |
User308915 - Posts: 3 |
Hi I read and followed the steps from a few of your guides to try to solve this problem but it's not worked for me at all. I want to have access to at least 10 years of intraday historical data for backtesting reasons, or as much data as it's available. However I can only see data beginning from mid May 2019 for the MES futures. I'll attach some screenshots with my current settings after I followed your guides. Please help me fix this and don't just refer me back to those guides, but help me identify the specific problem, because this has already taken up a lot of time to try to fix let me know if you need me to provide any other screenshots |
Private File Private File Attachment Deleted. |
[2024-07-02 13:46:31] |
my current data settings
Private File Private File |
[2024-07-02 13:57:15] |
Sierra_Chart Engineering - Posts: 16292 |
This data is not available anywhere because it does not exist. You should be aware of that. You need to use ES futures. Not MES. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-07-02 15:08:22] |
I can get longer term ES data like you said so I'll use that. thanks for the guidance. And no I was not aware, please would you link a page where I can find the different historical data amounts you have available per symbol? I have not come across this information on my own |
[2024-07-02 15:56:02] |
We do not have this information: please would you link a page where I can find the different historical data amounts you have available per symbol? You need to ask the exchange regarding listing dates, for the different contracts.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2024-07-02 15:56:15
