Date/Time: Sun, 08 Sep 2024 00:28:26 +0000
More details on Service Package 5
View Count: 143
[2024-07-02 06:01:18] |
User749090 - Posts: 2 |
1) should i open separate broker trading account, to access the service package 5 data ? 2) if any please send me more information on that. |
[2024-07-02 14:14:58] |
What are the exchanges for which you are wanting real-time data? Also, in order to connect to data and trading services, you need to be on one of the "Integrated" packages. Refer to the following: Description of Service Packages and Pricing: Integrated Packages For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-07-03 08:01:52] |
i need to get Futures CME data. And please tell me which package is suitable. I am planning to only get real time data (with advance features) from sierra chart, and trade on my separate broker account. Date Time Of Last Edit: 2024-07-03 08:05:46
[2024-07-03 14:08:49] |
In order to get real-time data and have the advanced features, you would need to be on the "Integrated Advanced" package (package 11). Refer to the information on the packages at the following link: Description of Service Packages and Pricing: Packages In order to get real-time data for the CME Group at the non-professional rates, you need to have a live, funded, futures trading account. And you need to be able to connect your Sierra Chart software to that account at least once a month for verification. Refer to the following: Real-Time Exchange Data Feeds Available From Sierra Chart: Understanding and Accessing Data From the CME, CBOT, NYMEX, COMEX Exchanges If you do not have an account that meets the above requirement, then we recommend the solution outlined at the following link: Easy Solution to CME Funded Trading Account Requirement Once you have worked out the above, then you can setup the data by following these instructions: Denali Exchange Data Feed: *Setup Instructions: CME/CBOT/NYMEX/COMEX Exchanges* For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
