Date/Time: Mon, 28 Sep 2026 12:09:33 +0000
[User Discussion] - Newbie needing help
View Count: 741
| [2024-07-01 19:39:52] |
| User932691 - Posts: 1 |
I am brand new and feeling slightly overwhelmed haha I don’t know if it’s still in the trial phase, but my chart book when I open Sierra Chart says example chartbook. For clarification I have service package 11 and I am running 2652. I’m not sure how to get rid of the example book, because I have looked and not seen any way to delete it. Maybe it was from when I first opened SC that something was selected and I didn’t realize it. Any help would be greatly appreciated! Thank you |
| [2024-07-01 20:08:34] |
| Sawtooth - Posts: 4355 |
Change its symbol, bar period, etc.: Chart >> Chart Settings then rename it: File >> Save As You can open a new chartbook: File >> New Chartbook, then File >> Find Symbol, then rename it: File >> Save As |
| [2024-07-02 13:28:51] |
| John - SC Support - Posts: 48028 |
Also refer to the following: Chartbooks (Workspaces): Deleting a Chartbook Chartbooks (Workspaces): Automatically Open a Chartbook Along with other information on that same page regarding Chartbooks. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
